Need some suggestions on best way to mount custom rear bumper on. Im using a piece of 2"x6" 3/16" tubing. Any help.would be appreciated.
if you want it to sit flat against your existing mounting plate then drill holes in your tubing to match those holes,fish the bolts in from the inside and weld them...other wise drill bolt holes in angle iron then weld it to your tubing...easiest of all is just weld it in place
You can make them quite easily.... about 1.25" standoff with 4x4x.25" box tube and 4"x.25" flat stock.... I did... piece of cake. Use the two outer mounting bolts on each side and cut the plate to contour the frame rail and mirror the holes on the inner side of the brackets. The bottom mounts are .25" x 1.25" stock1/2" x 13 bolts
Then build yourself a swing-away
