Can't say im very familiar with this one. Looks tough. Got any pics, how was install?
Will have to dig around for some pics.
Install was relatively easy. Did it in my garage with the help of a buddy. The most difficult parts of the install were two bolts on the bumper and getting the door to tire carrier adjusted correctly.
The two bolts were difficult because there was a whole lot of swing room for the wrench so it took a few minutes to get each one tightened down.
The adjustment was difficult because you have to try each adjustment with the tire on the carrier. If it's not right, you have to take the tire off then move the shims around, bolt it all back together and try it again.
If I remember correctly it was about a two and a half hour install from start to finish with about half an hour spent adjusting the carrier arm.
