What is everyone using for rear cargo lighting? @Blue Baby Soundlooked like he had a 50” Baja Designs light bar his was so bright. I need pics of your setups along with a description.
Administrator
I'm still playing around with ours. But to start with we ordered a LED strip from Amazon LINK and a cheap switch LINK. Hindsight should have done a better switch.
On Wookiee I ran some 14/2 wire from the Intech pod to the rear with a disconnect for when the top is off.
2 strips of LED tape the length of the rear window. Using some double sticky tape because the LED sticky tape stunk.
On Brutus I used the remainder of the LED tape and tapped into the dome light. I soldered the connection to the bulb so I can remove the bulb to take the top off. (just a temp solution)
