So I did my fluid change on the rear diff and when I pulled off the rear cover off I notice that the driver side shim was sticking out. I tap it back in. Should I be concerned about it later on.
It's the oem gears but I think that someone has been in there before me because it is the 4:10 gears instead of 3:73. It was past the bolts.
Past the bolts huh. That far I'd be concerned there wasn't enough carrier bearing preload holding them in place.If you haven't done any differential service / repair in the past you might want to find a good mechanic to take a look.
