1 - 9 of 9 Posts
My Rear Electric Window stopped working. All Other windows work fine. Does anyone have good troubleshooting tips?
have you tried unplugging and then re-plug in the door wire harness? The cover is beside front seats in the B pillar near the floor. Just slide the front seat ahead and you will see it.
Thanks for the quick response and advise, tried that it did not work, I assume it is not the fuse since the rest of the windows work? Any other thoughts?
Are you talking about the rear window electric heating element or one of the rear (side) windows that moves up and down electrically?
Commo
I had the same issue with my drivers side rear window. One day I go to get into my jeep and I close my door and next thing I notice is my window is gone. Had not even started the jeep. So I go to raise the window and nothing happens. It feel inside the door all on its own. I remove the panel to see why it would not raise up and to see why it feel and during that process it started to work again. I would like to say I fixed it but I have no idea why it started to work again. So long story short remove the panel and start to play with it. 2015 jku
Discussion Starter #7
Commo, Rear right window that moves up and down. Any advise?
Eddierayhouston: Is it easy to remove the door panel? - Anything else to look for?
Sorry, my experience is with the rear window defogger -- mine (and I believe a bunch of others) went in-op when one of the two contacts came loose from the window...covered under warranty in my case, which was great as apparently a new rear window costs $1100...
Commo
1 - 9 of 9 Posts
