1 - 14 of 14 Posts
Help I need a rear gass for a Steelhorse Hardtop. I was told that a factory glass may work, Any help would be great. Thank You TonyO.
Brewing, Skiing & Jeeps..
Given that I don't know what it is I likely will not be able to help, but what is a Steelhorse hardtop? Is that a brand? Sorry in advance for what may be a dumb question.
Yes Steelhose was a brand that made jeep parts/tops. They went out of business a while ago.
Gotcha. Do you have a picture? It may be pretty obvious that it would or would not fit if you can post a picture. If we get that far I can do some measurements for you on my top to see if perhaps the factory glass would work.
Any way to make a template of back glass, I am thinking of making one out 1/4 in acrylic already bought 6x4sheet $140 , Junkers by me want rear glass $400. Auto new want $500 on line $250. Any ideas?
Jeep rear window Steelhorse
I too have a 98 TJ with a Steelhorse hartop. My rear glass recently broke. No local glass shop will make it, liability issues related to it breaking from stress from the support struts on the glass is what all of them said. So I am in the process of cutting out a new rear glass from scratch resistant Lexan with a water jet this weekend I hope. I'll post the pictures after its done.
Steelhorse tj hard top rear glass
plexiglass did work but it's not a weather resistant option because of the flexing. While playing in a jeep junkyard i did find that the YJ factory hard top glass works in the tj steelhorse hard top dimensionally and the hinge holes line up. The only downside is that you will have to play with the steelhorse bottom plastic seal to make it fit with the door and there are no holes for the gas prop rods.
I used a yj lift gate assembly on my tj steelhorse hardtop it fit perfectly. All I had to do was move the lift gate support brackets up 10 inches on the inside of the top. Now I have a wiper also
I really need a pic of this- bad. I have no idea how or what the latching hardware looks like. I have just the bare glass. I don't even know what parts I need!
Wow- what a journey on this back glass! I got the correct struts from my local trailer supply- oh yeah- now I am taking the jeep in and they are going to adapt my stock hardware to the steel horse glass. Then the hard top stuff is pau (means finished in Hawaiian) - then on to other stuffs!
too bad this on the TJ forum- this is a YJ thingy I am afraid.
1 - 14 of 14 Posts
