1 - 14 of 14 Posts
Hi everyone!
Just took possession of my first jeep 2 days ago, and god it's fun to drive!
I have a question concerning the rear seat tho.
It is a 2014 Sport 2 door model. I saw that I can flip up the rear seat to have more cargo space when needed and that it was holding up using what looks like a spring mechanism. I was wondering if it is safe to ride like that or if due to bumps/acceleration/braking the seat will always move back and forward and damage the only 2 spots in which it is attached to the floor? And if it can damage the attaching point, is a bungee cord to attach the seat to the rollbar in the top string enough to keep it from moving?
I know I can totally remove the rear seat, but I'd like to keep it inside in case I need to carry people.
Thanks for your help!
I do that all the time, using a bungee cord (very short one) from the folded seat to the soft top bracket on the roll bar. I haven't had a problem yet.
With the way I have my driver and passenger seat situated in mine, if I flip the rear seat forward, the front seats keep bit from falling back! I have to slide the front seats forward in order to get enough clearance to put the rear seat back in place
I ride with the rear seat flipped all the way over and don't need anything to keep it there.
Wonder if the spring rate changed... If I accelerate quickly the seat tilts back and then forward and hits my seat. Seems like it should latch in that position...
A short bungee cord around the passenger seat head rest keeps mine from bouncing back and forth. One of these days I'll just take it out and have even more room.
My 07 has that issue with the seat bouncing back and forth. I just removed mine completely but I did see a product designed to keep that from happening.
Here is the link but it says it is out of stock.
Die-Tech Off-road Seat Retainer
that looks like a terrible idea. The leverage it'll be applying (being nearly parallel to the seat) seems like trouble.
I don't think it is applying any force but rather just works as a bump stop so the seat won't swing backwards.
1 - 14 of 14 Posts
