Just flex the rear axle so one side is as far up as it will possibly go (either to bumpstops touching or rubbing fender) and measure the space between the top and bottom shock mounts. Now take that measurement and make sure the shock is just slightly shorter at max compression. Any longer and you risk damaging the shock from bottoming it out.
