Hello all, just finished putting my OME 2.5 lift on. I know the rear sway bar links are to short correct? I put Adjustible fronts on to correct sway bar angle so I would figure same for the rear correct.I'd figure it's just as important to correct there lenght as well. Don't want to be tweeking my stuff you know.
I have done a search but not finding anything for up to a 3" lift. I gained about 2 3/4" over stock height with OME. Any help or pointing me in the right direction is greatly appricated.
Knows a couple things...
That's not enough suspension lift height to worry about for the rear antiswaybar, its exact angle is not critical.
I have your exact lift and have done nothing to the rear sway bar. I did however break one of my front links the first time I took it out on the trails and didn't disconnect. I replaced with a Currie Anti-rock sway bar which is expensive but worth it.
Thank you, Jerry. Your a man of much knowledge glad you chimed in.
