My 04 TJ doesn’t have a limiting strap. I’ve tried to find one and no luck so far. Does anyone know where to get one? Also could someone post a pic of what it’s supposed to look like, so I know what I’m looking for?
Thanks
On mine the hinge has the stop, a bulge in the outer side just inside the hinge. You know outside in.
Same here. The hinge stops it at a point just past 90 degrees.
yah mine didn't have anything like that........have seen struts like a hatchback lift strut fixed to the rear gates for assisted opening and a potential limiter.
there is a forum member that does braided paracords for doors, and could probably make a custom length/width for you.
without a wide swing you'd never get a hardtop open with the spare mounted.
Sooooo
Doesn't have one because it's not supposed to have one.
