There are a couple of different seal designs, some larger than others and some smaller. Try going up or down a year.
And before you install another new one, take the driveshaft out, and rub a little tranny fluid on the shaft that slides into the t-case and then slide the seal over it. If its the right one it should clean the shaft and push the fluid back. Thats to make sure that the contact between the seal and shaft is right.
