1 - 9 of 9 Posts
the hose is routed from the back corner of the hardtop, through the carpet on the drivers side, through the firewall and into the washer reservoir. not sure what else to say
I was thinking the rear washer is not spraying?
Check both hoses coming from the washer resevoir tank on the driver's side of the engine compartment. They are located just forward of the brake booster, in front of the engine computer. You'll see two black hoses coming from the tank.
The hose plug in right next to the wires into the hard top.
Mine never really sprayed out more of a stream of water. Mine works like shit. I almost never look out the back window anyhow. After years of driving a pickup with a shell on it I just uses my side mirrors.
1 - 9 of 9 Posts
