My Jeep has a large leak in the lower passenger side corner of the rear window / tailgate. It leaked when I purchased it last year but it is still leaking after having my local jeep dealer replace it twice !!! I know it's coming through the rear corner seal because light from a flashlight makes its way through when shining from outside the seal. I have attached images, anyone know a solution? Different corner seal? Adhesive to secure it to the hardtop? As you can see from the last image it was a problem for the previous owner because the sub bracket is rusted.... The first pic is where the water runs in , if you follow the silver screw down to the seal from that point to the corner seal is where water pours in.
Thanks in advance
Jared
Thanks in advance
Jared
