I'm lost - how do you remove the rear wiper? The front come off easly but the rear doesn't want to budge. I slide the retainer clip down but no luck and I'm affraid to wrench on it due to the glass.
Need some advice please...
On mine it has a cover over where the arm attaches to the motor shaft. Take the cover off & theres a retaining nut you have to take off then the whole arm just slides off.
If its the same as mine, the retaining clip and a splined shaft, they can be a real pain in the ass. I had to adjust mine on my used hard top. all I did was spray it with rust check for about a week and just keep working the arm back and forth. dont try prying on it or anything cause you'll probably end up shattering the glass before you get the arm off. hope this helps
