My rear windshield wiper works, but you really have to hold the button in the right spot. I'm planning on taking off the dash and taking a look at the piece. Any tips as I get ready to get in there?
You should probably just replace the switch if it is acting like that. It should just be a single click to turn on the wiper and hold it down for washer fluid. If you have to "hold it in just the right spot" you are going to just frustrate yourself when you really need to use it.
you should probably just replace the switch if it is acting like that. It should just be a single click to turn on the wiper and hold it down for washer fluid. If you have to "hold it in just the right spot" you are going to just frustrate yourself when you really need to use it.
what he said!
Let me know if you find a place that sells these. Daveys jeeps asks $15. Mine is completly busted
THIS thread saved me $20! My whole square part inside was broken in half, the spring holders were broken, and the spring was bent! Looks like someone took a hammer to it! :p thanks again!
