I installed a hard top off of a 95, it has a rear windshield wiper and rear window defrost. I wired it all up and at first the rear wiper worked but has quite now. Was going to remove the motor but the arm will not come off. I have put penetrant on it and heated but it want move. Anyone have any good ideas before I cut the top off to allow a puller to work and yes I did release the clip.
The wiper arm? It's been a while since i owned a YJ with a YJ top but does it use the same design as the front wiper arms? There is a hole though the arm and you pull the wiper away from the window then stick a drill bit or a piece of wire that will fill the hole. Then gently fold it back towards the window and it will stop. This causes the drill bit/wire to press release the arm and you can then pull it right off the motor shaft spline.
