My rear wiper isn't working on my 2001 Sahara. Wiper fluid is good to go and everything is connected in the rear, but for some reason the wiper wont move. any suggestions? Do I need to take apart the motor? Help!
I would take the cover off the rear wiper and see if you have 12 volts at the motor. There is a suppose to be 12 volts at the park switch all the time (black /light green tracer. When you turn the wiper on you should have 12 volts on the brown/pink trace. If you do then it is in the motor. If you don't it is most likely the switch. The same fuse #6 is the power for the washer and the wiper.
