The factory mirror brackets on my 95 YJ look like hell, all corroded and chipped. Has anyone stripped and dipped them?
I didn't dip, but I did just finish repainting them. I used a heat gun to remove what little paint was left, sanded, primered, and rattle-canned some Duplicolor Chrysler black. Look much better. Maybe should've hit with some clearcoat, but I only had one day to work on them.
I just bead blasted and painted mine a couple weeks ago.
They were all corroded and chipped up too. I used semi-gloss black from TSC.
I repainted the ones on my 99. I used a wire wheel to remove all the chipped coating and corrosion, then put on several coats of flat black, then clear coat. They turned out great, and 5 months later, they still look great. :)
I used SEM trim black,selfetching paint just for trim matches most mfg perfect.availible in rattle cans and qrts.
