i am new to NH and im aware of the strict inspection laws.
is there a shop that can work with me?
i am not asking for an illegal inspection sticker, i just want a shop that isn't going to fail me for something as simple as having a shortened stock bumper.
everything about it is absolutely safe, from bushings, brake pads and no leaks
I am located in West Chesterfield 03466.
They can't fail you for the bumper. If someone gives you grief for that refer them to this:
Saf-C 3221.04 Bumpers.
(a) A vehicle shall be rejected if the bumper and its structural components are:
(1) Not attached to the front and rear of a passenger or multipurpose vehicle as manufacturer intended;
(2) Not attached to the front and rear of a pick-up truck as manufacturer intended;
(3) Located at an improper height as measured pursuant to RSA 266:9;
(4) Loose or improperly installed; or
(5) Rusted or damaged to a degree which does not effectively reduce the transfer of impact when engaged
If your bumper meets these requirements, they can't fail you.
