1 - 10 of 10 Posts
Just as the title says, I'm looking for recommendations on a heavy-duty tie rod for my 2007 JK. I'm running a Rock Krawler HD tie rod now and I need to replace it. I was wondering what other options I have for a reasonable price.
Thanks!
I run Synergy great TieRod , are you just looking to try something different than RK ?
Is this the new aluminum RK pro tie rod? Why are you changing away from it? I'll get the Synergy when my factory one bends, I'd do the RK if I could but it won't work with my REIDs.
Discussion Starter #6
It's not the new aluminum one. It's an older version..their HD tie rod. The ends have some play in them, plus I have bent it with much off-road use. Nothing major but the play in the end is what makes me need a new one.
I was looking around and Synergy was a thought since I just bought a new Synergy draglink. I was thinking about going with RK again but seeing the new one and how much it is, I think I may stick with Synergy.
I have a T6 Aluminum custom tie rod.
I've never heard of those. Can you elaborate?
A local shop fabs them (Letzroll in Mesa, Arizona). T6 is supposedly very strong. The benefit of aluminum as I understand is it will bend and "spring back to shape" before it breaks or stays bent.
what about a DOM tie rod with heims? if you do manage to bend it or wear out a heim, all the parts are easily replaceable. I got my setup from ruffstuff, paid ~$125 iirc
1 - 10 of 10 Posts
