I have a new set of Recon clear fender marker lights. Only negative is that the clip on the top end is snapped off on each one.
I called Recon and they said I could glue it back on with gorilla glue (strong stuff) or put a small screws from the inside after installed to help hold it or foam tape that edge or they said just snap it in the way it is and it should still hold.
I happened to have two sets when I was installing these so I just used the other set.
These are plug n play.
60.00 free shipping
