1 - 20 of 20 Posts
I have a 04 TJ. My instrument panels gauge have red arm dials. I have seen that Blue LED turn them purple......Should I still go with Blue?
i personally like red but my jeep is blue i went with red because everybody i know down here has blue leds in their vehicle and i wanted to be different so i went red
And here's what I did after I made my gauges red
Vehicle Car Commercial vehicle Vehicle door Family car
Yes the later models with the orange needles will look dull purple with blue leds and are hard to see. Mine were like that. I pulled off the needles, scraped off the orange on the backside and painted them white. They glow bright blue now. The needles come off pretty easy. Start the engine, then take pictures of the exact positions, then put them back with the engine running. The speedo I had to do wile driving using a GPS for speed.
Red would be easier on your eyes, plus it doesn't affect your night vision...that is why the military use red. I had blue LEDs in my 240sx convertible and they were WAY too bright, had to change them. But it's whatever you like.
Commercial Member
The military uses red for many reasons. Any light will affect your night vision. There are a lot more technical reasons that we use red than just simple night vision.
Like I said, easy. I used a fork to pry them off. I've had them off more than once to redo some things.
I was torn with the same dilemma when I changed mine. I decided on the blue and don't regret it. It is easy to see and read and doesn't bother my vision. My thought was if I didn't like them I could always order red and live with the blue or stock till they came in. They aren't that expensive that you are out of a lot of $$$ if you don't like the result. You could also sell the disliked color here on the forum to recoup most of your $$.
Discussion Starter · #13 ·
Cool.....How about putting the speedo back on? Did you drive and do it by yourself? Also you mentioned taking a picture before you remove the arms. If you take them off from a "engine off" position they want just reset?
Yes I did the speedo myself. Left the plastic cover off and the whole cluster loose and just plugged it in and drove. It took a few trys to get it on at the exact speed.
With the engine off, and the cluster out, the needles just flop/move around. There is no "reset" position. The system does not know there the needle is pointed. Take the picture with it running. And put them back with it running in the same position as the pictures. Obviously the water temp can change, so do it when cold.
Discussion Starter · #15 ·
Thanks for the input. I have a couple other questions then I will leave u alone.
1) my gauge arms have red that extends to the top of the back center tops. Doesn't look like you can scrape these down?
2) can u send me pick of you dash with the light on at night and what they look in the day light?
I painted the whole center black
It would have to be next week.I don't have any of the dull purple they were
Discussion Starter · #17 ·
One more question....I have an 04 TJ. I have read all the threads and everyone went with 74.....however when I look on the superb rights website they say 194's for my jeeps cluster.....Is this correct?
They are 74's and get the multi (I think they were tri leds)
Discussion Starter · #19 ·
Why not the 194's? .....just curious since thats what they suggest...
Thanks for answering my questions by the way...
Totally different bulb base
1 - 20 of 20 Posts
