21 - 32 of 32 Posts
Also is there a certain year I would need out of one of those types of vehicles
Has to be can bus radio which was not around 2007
And not in liberty till 2008
Also because of problematic cd drive I would avoid 07 and 08
Any high speed bus vehicle RES 09-2011 would be plug and play without a security code needed
2012 and newer would need security code
Plus RES come both with and without Sirius tuner and with and without uconnect buttons
Supposedly original owner got it on a little card with rest of paperwork
Some claim also sometimes on a sticker on back side of glovebox but I have yet to ever see one of those stickers at junkyard
For a 2012 avenger low bus RBZ mygig radio I picked up at junkyard, I called local dodge dealer service department with both that radio serial number and junkyard vehicle vin and eventually they were willing to look it up on their computer for me after first claiming it would not be possible without vin of vehicle it was going into
I explained that I had it wired to an avenger TIPM and Skim/ignition module on top of my fridge in my kitchen so there was no vin on installed vehicle
He gave me a code claiming it probably would not work and it worked fine
Wrote it in perm marker on top of radio body
The dealers are hesitant to look them up without proof of vehicle ownership so good luck
For mygig it is four digits with each any number 0-9 so 9999 possibilities
On an RES four digits entered with station select keys so only 6x6x6x6 or 1296 possibilities
And it locks you out for a period of time after 3 failed tries
I also like the pre anti theft res better as you can remove 4 screws and swap Sirius module but by antitheft years it was part of main board not a separate module
Also it is the antitheft years that tend to have the failing solder joints as referenced in video I posted
Discussion Starter · #26 ·
Thx for the tip.
2003 Rubicon, manual trans, Atlas transfer case, Nth Degree Mobility kit and more...
Have a mint radio I believe is from a 2014. Is there a way to find the year?
Al in Tucson
All the can bus radios I have see have a date code on the label
All also have a three digit model code on front lower corner
RES, REQ,REN,RER, RBZ,RHB, RHR
Also 2012 and newer say “anti theft”on face
Hoosierdaddy, I also have a 2014 JK and have a 130RES as well as a 730nRHR I'm no longer using if you're looking to purchase.
Discussion Starter · #31 ·
I am looking to purchase a replacement radio for my 2014 JK Wrangler Unlimited sport. What are you looking to get out of either of those two radios. Is the second model the touchscreen radio? And do you also have the antitheft password For them?
Thanks Hoosierdaddy
21 - 32 of 32 Posts
