1 - 16 of 16 Posts
I have an '08 X, where can I find on the vehicle what the gear ratio is? I believe it may have 3:21s. I am running 315 MTZs, so what would a more appropriate ratio be? Finally, how difficult is the process of changing out the gears? Thanks in advance for any help you can give me!:confused:
If you have a manual you can have 3.21 or 3.73. The 3.73 was an upgrade option. If you have a automatic tranny then you have a 3.73.
I have 4.88's in mine and think they work great with my 35's
It's a manual. Did you do your own work?
If you log on to the Jeep website you can request a "build sheet" with your V.I.N. They will e-mail you the build sheet within a day.
I have a 2010 JKU automatic with 35's. I went with 5.13 gears. Changing the gears takes some tech experience. My advise would be to take it to a trustworthy shop who does gears.
What were the improvements with the gear change? More power? Pick up from a stop? Pick up at speeds? Mileage?
Supporting Member
Re-gear doesn’t give you more power as it has nothing to do with the engine. It does make the driveability 100% better. Lowere RPM, better MPG, less doggy at accel, so on…A 3.8L with manual would benefit from 4.88 gears for 35’s.
-Dan
Will do. Thanks!
I have a 08 auto with 35"s but it's also my daily driver. Would 5.33 gear ratio be too much for toll road speeds?
I went from an '08 with 3.21 to 4.11. The difference was dramatic, its like a totally different vehicle. RPM's are definitely higher than before but now I can actually use 6th gear on the highway.
How much higher? Auto or manual? I have an 08 with 3.21 gears (manual) on 33's. Considering either 4.10's or 4.56's. I do a mix of highway and stop n go street driving.
It's a manual. When I drive home today I will take down some RPM numbers at different speeds in all the gears so that you can compare it to yours. I am very happy with the 4.11 gearing and don't think I would go any higher unless I was considering putting on 37"s. Shifting is much different now, I find that i cruise around in a higher gear than I used to and 6th gear isn't completely useless anymore, I love it.
There's no 5.33. Do you mean 5.13 or 5.38?
3.8L, automatic, 35s, 4 door and I was still disappointed when I switched from 4.10s to 5.38s. Streetability didn't improve as much as I hoped, felt like I just got back my overdrive and 4:10 OD off drove better than 5.38 OD on around town.
Oh yea ha that's what I meant. With the above stats would I notice a difference from 3.71 to 4.10 or 5.13?
Here are the numbers I got last night comparing engine speed to road speed with 4.10 gearing. You should be able to use this to compare to your Jeep with 3.21 axle ratio.
1 - 16 of 16 Posts
