2004 Wrangler 6cyl manual trans. I took out a bolt (13mm x 3" LG w/ 1" thd) which should not have been removed. The bolt was on the driver side below the level plug beneath a tab. The trans is still installed. The bolt cannot be reinstalled something inside of the trans has rotated to prevent the bolt from entering. I expect it may be a reverse idle component. Can anyone help me get this bolt reinstalled. Or do I nee to take it in to a transmission shop?
Got a picture of the bolt in question?
By the way, welcome to the forum!
Mac
The bolt came from just to the right of the case seam near the center of the view in the attached pdf. (Definitely looking for some Wisdom from above.) Thank you for serving in the USAF.
zombie & ninja slayer
Somebody else on here did this, if I remember right they had to pull the tranny to fix it
