1 - 12 of 12 Posts
Sorry. Search sux using phone. How would I go about removing the side marker lights. Not the bulb but whole hoising. I have no patience and have tried once but afraid I will break or damage something. Is there a clip? Buying the clear ones but wanna know how to remove first
Thank u...is there a way to remove the plastic rivets or screws without that tool? Located at the edge of fender flares
I made the tool in the video with a channel locks and a socket. Worked great for me. I guess you could just drill the plastics screws out and replace them from the dealership.
I wonder if this changed much in 2015? I am installing side marker guards that I got from Quadratec. Got the rivets out no problem, but I can't for the life of me figure out how to release the clip to remove the lens housing. Afraid of snapping something.
QUOTE=BetaMini;14138673]I wonder if this changed much in 2015? I am installing side marker guards that I got from Quadratec. Got the rivets out no problem, but I can't for the life of me figure out how to release the clip to remove the lens housing. Afraid of snapping something.[/QUOTE]
Been awhile since I removed mine but reading back thru my directions in a thread the lense has a tab at tge top you have to press to release it
thread
http://www.wranglerforum.com/f274/how-to-changing-to-clear-marker-and-turn-signals-573145.html
HI - anyone know how to release the light bulb from the socket on the fender side light? Bulb died but do not know how to release the bulb. Thanks!!! Edward
If you want to take out, just cut the rivet from inside, pull the inner fender out and light will come out. I purchased a set of rivets and rivet gun from Harbor Freight which match well..Almost exact. Easy
1 - 12 of 12 Posts
