Different inserts attach differently. It would help if you posted a picture
Stock inserts, as far as I know. Guess I'll just get in there and look. I was just wondering if they pull off, like the center dash bezel, or have to be unscrewed. Would save me the trouble of digging under the hood is all.
Reach down in front of the radiator and pinch them together. They should pop out fairly easy.
If yours have the Billet Grilles, get a wire coathanger and use the hook. Just slip through front let the hook grab the back and slowly pull. Make sure hanger is either to top or bottom of insert and the top or bottom will pop out. If no Grill insert, do as mentioned squeeze from radiator side and push.
I pulled mine out to paint them. I put my hand inside down towards the bottom where i could grab the back side and gently yanked back and forth till it popped out (damn that sounds bad!)
