Hey, i have a 95 wrangler witth the 2.5 and the 231 t case. Could somebody give me some info on removing this. I just want to know before i start. My haynes book says to pull the tranny to take it out. I think ive seen something here that says i dont have to. Could i pull it off with out pulling the tranny? Also, should i drain gear oil and the atf fluids or is the gear oil contained? Thanks for the help guys.
Vendor
When I pulled one a while ago, I did not pull the trans.
I removed the both driveshafts.
I think there are 6 bolts, the one at top is NOT fun at all.
I use a transmission stand to get it off, it is heavy put not over the top.
I don't remember there being much a leak of fluids from the transmission.
It took about 2 hours...
Good luck
I didnt pull the tranny either.
I just pulled my tc mine only had 5 bolts. Removing the shifter plate and the tc shifter makes getting to yhe top bolts easy. I jacked up my tranny and put a jackstand under it , dropped the skid plate and lowered the tc with a floor jack. PS. dont forget to remove the vacuum hoses,wires and the tc breather tube.have a small drain pan ready mine( tranny)leaked a fair amount when I pulled the tc. Drain the tc first unless you like bathing in ATF.
Good Luck
Good Luck
This is basically what I did. Removing the floor plate makes the top bolts easy to access. Only difference is that I just crawled under the jeep and lowered the TC with my arms instead of using a jack. I will put some ramps under the front wheels if I ever pull it again so I will have a little more working room.
I already have a soa conversion so the only reason I have to jack the whole Jeep up is to work on the wheel
