Cant seem to find any info on replacing a side window in a hardtop. Somehow my son broke it with the lawn mower. I have to take a window out of an old top and put it in mine. Anybody got any tricks or advice on how to do this?
Thanks
I have removed rear quarter glass from vehicles many times, but never a Jeep hard top. I would suggest going to a local auto glass place and ask for advice. The glass I removed was from Honda Pilots and Odyssey mini vans. It is glued in. No fun at all to replace. Had to use wire inserted between body and glass and "saw" through the glue. This takes 2 people with tools made specifically for this purpose.
thats what I was afraid of - I hoped somebody on here did one and could explain it, but...
Thanks for the reply!
Commercial Member
I was just "Googling" this the other day while thinking about painting my hardtop. Here is what I found, hope it helps you:
QUARTER GLASS
REMOVAL
(1) Cover surface areas with protective covering to
avoid paint damage and extra clean-up time.
(2) Using a razor knife, slide the blade between
the quarter glass and the inboard edge of the reveal
molding.
(3) Cut around the interior perimeter of the reveal
molding and sever the cap of the reveal molding.
23 - 64 STATIONARY GLASS TJ
(4) Using a cold knife, cut the urethane around the
perimeter of the quarter glass.
(5) Remove the quarter glass from the opening
(Fig. 1) .
INSTALLATION
(1) Trim the urethane from the quarter glass opening
fence. Leave a 3 mm (0.1 in.) level base of urethane
on the quarter glass opening fence.
(2) Place replacement quarter glass into quarter
glass opening and position glass in the center of the
opening against fence.
(3) Verify the glass lays evenly against the fence at
the sides, top and bottom of the replacement quarter
glass. Next, make alignment marks on glass and top
with a grease pencil.
(4) Remove replacement quarter glass from opening.
(5) Position the quarter glass inside up on a suitable
work surface.
WARNING: DO NOT USE SOLVENT BASED GLASS
CLEANER TO CLEAN QUARTER GLASS BEFORE
APPLYING GLASS PREP AND PRIMER. POOR
ADHESION CAN RESULT.
(6) Clean inside of quarter glass with ammonia
based glass cleaner and lint-free cloth.
(7) Clean the outer edge of the window glass with
naphtha or a similar product.
(8) Apply molding to perimeter of quarter glass.
The butt weld of the molding should be centered at
the bottom edge of the quarter glass.
(9) Apply Glass Prep adhesion promoter 25 mm (1
in.) wide around perimeter of the quarter glass and
wipe with clean/dry lint-free cloth until no streaks
are visible.
(10) Apply Glass Primer 25 mm (1 in.) wide
around perimeter of quarter glass. Allow at least
three minutes drying time.
(11) Apply Pinchweld primer 15 mm (.75 in.) wide
around the quarter glass fence. Allow at least three
(12) Apply a 10 mm (0.4 in.) diameter bead of urethane
to the center of the quarter glass fence surface
area.
CAUTION: Be prepared to install the quarter glass
immediately after applying the adhesive. The adhesive
begins to cure within 10-15 minutes.
(13) Align the quarter glass with the grease pencil
marks and position quarter glass on fence.
(14) Push the quarter glass inward until the
reveal molding is seated on the hardtop. Use care to
avoid excessive squeeze-out of adhesive.
(15) Open windows and liftgate to prevent pressure
build-up while the urethane is curing.
(16) Apply 150 mm (6 in.) lengths of 50 mm (2 in.)
masking tape spaced 250 mm (10 in.) apart to hold
quarter glass in place until urethane cures.
(17) After urethane has cured, remove tape strips
and water test quarter glass to verify repair.
Here is the link to where this info is from:
Help! Hard Top side window removal - JeepForum.com
I took the easy way with the glass on my '80 CJ7 when some ass broke them all out at college. I put on a soft top instead.
AWESOME - thanks so much - dunno why I couldnt find this - doesnt say much for my searching skills
