2015 JK - Oil Cooler leak
I've managed to remove the Oil cooler, and taken a look at it. I don't see any cracks, but the gaskets are really worn and flat. I'm trying to weigh my options here. I can spend $150 on a new oil cooler, or $15 on gaskets, and risk having to take everything out again if the oil cooler is actually cracked.
has anyone just replaced the gaskets and that fixed the problem?
i realize not all situations are the same, but since this is a common problem, i'm hoping there's a common solution. just looking at it, it's obvious the gaskets are worn down to almost flush with the metal
I just did the seals and actually I did them as PM.
That said, if you perform a smoke test it any cracks will be obvious. It's probably the seals. :)
<D>
i'd look at the part # and determine what version I have...
they are on the 6th incarnation (AF)
the earlier the version , the more likely i'd replace the whole cooler
for the amount of work involved I would spend the extra $150 if it were me.
If you already have it apart, replace it. Mine went while I was driving and i poured oil everywhere though I had a very small leak and knew it was going to go. My 14 was around 70k miles
This is a great point and I should qualify my earlier comment to say that I have a 2017 so I *think* I had the latest model (if not the latest a later one).
<D>
just for the record
I would replace the whole unit
