1 - 10 of 10 Posts
I replaced my brake booster today and now the brake lights stay on. Is there a way to lengthen the booster rod that hooks to the brake pedal, or can the switch be adjusted. It was cold and snowing on me as I was working on it and I didn't feel like trying to become a contortionist to see how the switch is installed. Hopefully tomorrow is gonna be warm like the weatherman says because she's my DD.
guessing you have the shaft upsidedown or the switch was not reinstalled the correct way. I done mine while it was still on the bench. Did it fix the idle problem?
yup the idle now stays at 700rpm. I did have to rotate the rod to make it line up, I'll try flipping it 1st then I'll check the switch. Thanks
The brake light is controlled by the switch in the proportion valve. When the pressure is uneven theres a little rod in the valve that closes on side off ( front or rear brake) this is to ensure if you have a leak or blow a line you lose just that section not the whole system. When this is tripped it press the switch to and the brake light comes on.
Sorry, I meant the brake lights on the back not the one on the dash.
Ok well I crawled under the dash. The new booster rod is about a 1/4 inch shorter that the old one. I adjusted the brake light switch out a few notches. At first look I thought it was threaded and had a nut for adjustment, but it actually is notched and you just push it thru the holder.
I went with a reman from Autozone. It fixed the idle problem so I'm happy with that, and adjusting the switch makes the brake lights work correctly.
1 - 10 of 10 Posts
