replaced carb and lost mpg
1947 45
I have an 87 wrangler 4.2 automatic that I've had for a couple months now. It has 4 inch suspension lift and 2 inch body lift. Im running 35 12.50 15 Goodyear tires with Kevlar. When I first got the Jeep it ran rough but every time I checked fuel mileage I was at 15. It began to run rough and was puffing smoke so I put it in the shop and found out the carb had been filled with jb weld putty to fill a leak. I ordered a new Weber from quadratec to replace the Weber that was on there, now it runs great but im only getting 11. Any ideas of what caused it?
1 - 20 of 46 Posts
One possibility, its not tuned for your rig.
Jetting, tuning, CFM need to match properly.
Another idea, could be a vacuum leak or something not hooked up that once was with the old carb.
If its running rich, you will need to find someone who knows what to do. Changing the plugs may help it run better for a bit, but will not fix the problem.
Its not difficult really, carbs are really a dumb air fuel mixer; but finding someone who works on them is getting harder. I for one like them because they are easy, and if you are willing the internet and I could help you walk through it.
Basically, assuming you are right in it running rich, then you basically need to get new jets. If you do a search you should be able to find the sizes available and a starting point. Once you find out what you have, step down in sizes, one size at a time then go run your jeep. Once the plugs come out the proper color (milk chocolate brown, to light brown) then you basically have the mixture right.
also just read that part of the running rich could be too much fuel pressure; you could try to put in a fuel pressure regulator and set it to 3 lbs and see if that helps.
No most Jeeps don't get much mpg better than that. Some will post as much as 20 but my 2.5 TBI with 33s is dead on 15 everything is new.
no, Jets are typically carb specific.
Start with the regulator, and with new plugs check for the color. If you get a light brown/tan then you're as good as that gets. But if they are black then you need to re-jet. At that point is where you would verify what you have, and buy a few sets smaller. They should be fairly cheap, between $4-$6 a pair.
The first thing is getting the jets set so that it runs well under full throttle, then tuning the metering rods and any power pistons to run well under part throttle conditions. would read up a lot on carbs and order a tuning kit. It takes some time to get right, but a proper carb will run very well.
Discussion Starter · #13 ·
Ok ill get some info on tuning the carb. Its a Weber k551 from quadratec. It runs awesome down the road as is, about 1300 rpm at 55. But I hope with this great information and a Nutter bypass I should be even better
Im assuming that is a 3speed auto?
If so, I believe 1300 at 55 is a bit low; the 4.2 is a torque motor, but honestly it likes a higher rpm at speed. More like 1800-2000 would be better at 55; not that it cant do it, but lugging the motor like that can also drag down your mpg.
BTW, did you change into those tires before your last mileage check? I would suspect your odometer is off unless you changed the speedo drive gear.
I just ran a gear ratio calculator and it suggests your speedo is off. At 55, assuming stock gear ratio and the 35" tires, your tach should read about 1800 at 55; otherwise your gear ratio is 2.5 which was not an option on the Wranglers.
Discussion Starter · #15 ·
It is a 3 speed automatic. It had the wheels and tires on it when I got it about 2 months ago. I was told it had been geared and i checked the speedometer with my gps and it was correct. It did run at w higher rpm with the other carb because it kept trying to die so I had to rev it higher to keep it going
Discussion Starter · #17 ·
Yeah. Im headed to the parts store for a pressure regulator and some jets and a new inline fuel filter now. Im hoping to see something over the 15 I was getting while it was blowing black smoke and leaking all over the place
Im thinking the regulator will help a lot; and then if you want to check for the jets.
You should verify what you have for jets before you go buy them, if not you have a chance of getting the same ones again. Not to mention, the parts store will probably not have them in stock.
Discussion Starter · #19 ·
I just got back from the parts store with the regulator plugs and filter. When I went to leave the Jeep wouldn't fire. First time I've ever had that happen. I tried for about 5 minutes with no luck. Finally put it in neutral and rolled it down the hill and it fired up, blew a big cloud of smoke and the whole way home the tach said 1800-2000 @ 55
Thats what the calculator said using the standard equipment axle ratio of 3.55
But your starting issue leads me to believe there is too much pressure or a leak causing gas to dribble into your cylinders. Basically, it flooded out while sitting there.
1 - 20 of 46 Posts
