So basically I want to use my Soft top because I missed it too much. Took quite awhile to get it right but I did....kind of. Keep in mind I had to replace the fabric and used my old frame. As I finally hooked up to my Jeep I realized that in order to install the two Locking Clips I had to put the Metal Support bracket behind the Header. :pullinghair: I really would like to not disassemble and reassemble the whole thing again. Any ideas to get this to work?
Thank you for any suggestions.....
Not sure I completely understand the issue. You forgot to put the locking clips back on is thst it? If so then yeah the right way would be to take it apart and put them into the frame.
I guess if your feeling lazy tho some self taping screws would probably hold them into that plastic. But I would just take it apart and do it right if I were you, its likely going to save you some headaches in the future.
