I have one bulb in my Factory Fog Lights that is burnt out and I am wondering what you guys recommend for a replacement? Just a stock bulb or what? I am also looking at replacing my stock headlights what do you recommend?
Luke
Retired Moderator
I know it is a 55 watt bulb and do not go above that wattage as it can melt down the harness or so I have read. You may want to replace both as one will be dimmer than the other and the one that works most likely will fail soon after.
I was trying to decide just to get replacement bulbs at WalMart or order some PIAA replacement bulbs.
They should be H3 bulbs if they are stock. I put Piaas in mine and am really happy with them. Most decent autoparts store will have them in stock.
I am a dealer for PIAA so thats the route I will go.
