As opposed to replacing my steering colum with an adjutable one, what if I just use a smaller wheel. My main goal is to get more room for me between the seat and the steering wheel.
1. What is DIA of a factor steering wheel? Mine is 15" on the outside DIA.
***Is that how they are measured?***
2. I can buy a 13 1/2 wheel for around $60. I have power steering so should not be a concern. If it is OD I would gain a inch and a half which is what I need.
Thanks
Roger
remember that if its a 13 1/2 diameter the radius will only change 3/4 inch on each side, giving you only 3/4 inch on the bottom side rather than 1 1/2. i could be wrong... but that seems to make sense in my mind haha
You are right
I orderd a Grant steering wheel with a 11.5 DIA as opposed to the 15 inch stock wheel. This should give me plenty of leg/theigh room for me for under $60.00 with install kit.
Roger
