Replacing a side mirror on a '89 full door
Attempting to replace a passenger side mirror on a full steel door. Need advice. After removing the upholstered interior I don't see how I can access the interior of the door to allow me to replace the mirror and mount. How can I complete this? I do need to replace the entire mount/mirror.
The outside mirror is replaced from the outside. You have to pop off a plastic cover to access the screws. take a look not to difficult.
You don't need to take off the mount/base to take off the mirror. A 3/4" ish nut holds the mirror stem into the mirror base. Take that off, (watch out for the spring), then the mirror will pull out from the top.
