Hello!
So, I recently noticed the bushings on my rear lower control arm and track bar need to be replaced. As well as the rusty bolts. Seeing as this is my first time doing this :dance: I wanted to make sure I was picking the correct parts. As far as the track bar goes, I was looking at this:
Rubicon Express RE1686 - Rubicon Express Rear Track Bar Bushing Kit - Quadratec
I assume it comes with the sleeve and bolt (says "bushing and hardware"), but incase it doesn't, does anyone know what bolt goes in there?
For control arm, I found these (couldn't find kit, so bushing and sleeve separate):
http://www.summitracing.com/parts/exp-15-11255
http://www.summitracing.com/parts/exp-90-2310
And also, what bolts for these? I saw conflicting answers on one thread, one said 7/16 12x4.5" grade 8, but the other said 9/16?
:Thanx:
P.S. My kit is comparable to this one, not sure of the exact kit because it was already installed when I got it.
Pro Comp Suspension Part K3056B - 4 Inch Lift Kit with ES3000 Shocks
Hello!
:Thanx:
Note you say control arm but the forst ling are bushings for the sway bar
