I have factory fog lights on my jeep but really would like to replace them with some ipf's. Can i just cut the wires off the factory fogs, remove them, and wire up the ipf's using the same factory wiring and switch? The ipf's come with 55 watt and 100 watt bulbs but if i just stick with the 55 watt bulbs will the factory wiring and switch work?
yes, i have the same lights on the factory wiring and i put the 100 watt bulbs in.
You would need to find out the current draw of the factory fog lights. If the lights you want to install are = or less than the fogs, you are good to go. My guess is that what want to install will draw more current which may OL the wiring or switch.
