My mechanic of over 30 years said that's out of our league. Called the place they recommended $300 to do front and rear. What's going on? Freaking crazy
Sounds like he just don't want to do it if you ask me. I'm new to the jeep and have been in my Dana 35s ass 3 times in a week and replaced every seal and bearing. It wasn't easy but I pulled it off.
It's a pretty easy DIY fix of you wanted to do it..but I must warn you whoever put the pinion nut on from the factory whether it's machine or man, tightened the hell out of it lol but I agree I believe your mechanic was to lazy to do it. It's an hour tops job.
The pinion nut is the only thing that worries me.... Getting it loose and retightened the same amount. I don't have an air wrench but have a 1/2 breaker bar. I guess I'm gonna hafta try that.
Um yea don't even bother without an air gun trust me it doesn't work. As for tightening it to the same use a punch and make some marks on the thread and tighten back to those marks it not hard.
Actually you don't have to have an impact because I didn't. I used a 3/4" drive pull handle with a cheater pipe. It's bad tight that's for sure. The nut is either a 1 1/16 or 1 1/8 I can't remember exactly. I'm pretty sure it's 1 1/8th. But yes if you had access to a impact it would be sooo much easier.
That is the way I have done it Center Punch Pinion-Pinion Nut & Yolk & count number of threads sticking out past nut Proir to taking apart Then Realign everything & tighten back to where it was.
