1 - 20 of 36 Posts
THESE: Bosch European H4 Headlights - PAIR
Best bang for your buck. Choose your favorite flavor of bulbs and your ready to go. I chose HIDs but some people prefer just the standard H4 bulb.
^^^ X2.. This is what I did, Alex is right for the money you won't do better. Also consider an upgraded harness from RJM or Susquehanna Motorsports. Very easy to install.
RJM Injection Tech — Headlight Harness
Susquehanna Motorsports Transition Upgrade Headlamp Harness - RallyLights.com
What is your budget?
busdepot Bosch H4 housings/the inexpensive Hella bulbs on the same page/RJM harness ~$120
Cibié H4 e-code housings, Osram bulbs and D. Stern wiring kit ~$300
Truck-Lite LED lights ~$500
J.W. Speaker LED lights ~$800
Maybe I dont know what I'm missing, but I had KC replacements in my 99 and thought they were a great upgrade for about $100. Just bought a second set on eBay for $63 shipped, brand new, for the 06 I have now. Wish I had kept them when I sold my 99!
Just be careful of crap on eBay... If its not DOT the man can give you a nice fat ticket... Down south in the third world country I live in AKA South Florida... It's not really an issue.
KC's are DOT Legal
Full Size Jeep Dr.
Delta housings and 60/55W bulbs here, along with a custom harness I made myself. Easy enough to do, and much less expensive than a pre-made harness.
If you live in the land of salt like I do, make sure the relays and connections are weather-proofed, regardless of who makes the harness/relays.
Commercial Member
Truck lites are down to $390 at discount fleet supply fyi.
Agree the stock headlights suck. :facepalm: The 2014's are supposed to come with better ones (maybe then available from Mopar). You don't say or show what year your Jeep is, but if it's a 2013 the simplest, cheapest alternative is to change out the bulbs to Philips X-Treme bulbs. There is extensive discussion about the pros and cons of other alternatives on this site. Some people are Trucklite fans, some are JW Speaker and a host of others. HIDs may not be legal in your area, are very costly and can present serious issues of blinding oncoming drivers if not correctly installed with the right housing.
So you might want to do a little research elsewhere on this forum and then pick your poison. I got the Philips bulbs, easy peasy and they are adequate.
Well this is the TJ section, so we cant just change bulbs like you JK folks. Have to upgrade from the sealed beam headlights!
:hide:Thanks for the correction. Didn't see the masthead. I'll go back to the JK section now. :whistling:
1 - 20 of 36 Posts
