This weekend I'm gonna put in a new TB gasket, just got a simple question for yous. Besides making sure the surface is clean, do I have to add RTV to the base of the Intake Manifold Flange and the bottom of the Throttle Body flange? Or will the gasket be a good enough seal alone? Thanks
Gasket will be fine. It is really easy. It should be held on by safety torx bolts though. Should only take about 10 min to do.
Thanks, I wasn't sure bc the manual didn't specify for the TB Gasket if it required a cork/rubber gasket and/or sealant.
