I am new to the forum. I have a problem with resetting the change oil message on my Wrangler Sahara 2008. I followed the instructions in the manuel to no avail.
Your help would much appreciated.
Viviane.
I think on my 2011, it's turn the key to the last notch before the starter kicks in, press the gas pedal three times, turn off and remove key.
Sent from my SM-T550 using Tapatalk
Viviane.
If you're turning the key to the "on" position and then "slowly" pressing the accelerator to the floor and slowly back up three times within 10 seconds it should re-set. If not, there's a glitch that a dealer might have to troubleshoot. If you're only pressing the trip odometer button when in the "on" position, that only temporarily re-sets the oil change message.
