1 - 13 of 13 Posts
My reverse grinds every time I go to put it in. Clutch pedal is fully disengaged. Whenever I go to first and then go into reverse it doesn't grind! Wtf!? It has an ax-15. This is my first standard vehicle and first jeep. I do know how to drive.Help!!!
does it grind significantly to the point that you cant go in gear? A little bit wont hurt.. mine grinds a bit, i just make sure to throw it in reverse fast and i have no issues. My 98 volvo 5 speed had the same thing and it was still going strong until the day i did a title swap on it a few months back.
It grinds to where I'm scared to put it in farther....that's what she said! Haa. Well it only does it the first time. Usually after it grinds when I go back again it doesn't. Also when I go to first gear first then reverse it doesn't.
Thats because reverse isnt a synchronized gear. Just go into a forward gear before shifting into reverse and you should be golden!
This. It's normal. That's how I've been shifting into reverse with my 89 AX15 for years. I go from first to reverse. What you can do to help is to change your fluid to full syn gear oil 75W90 or full syn 10W30 motor oil.
Thank you all for reply. Whenever I go to first and then reverse, like guys said it, it works fine with no grinding. If something else happens ill post for some help. Thanks!
Mine is easier to go 2nd, then rev, but as said any forward gear works.
Yeah ill try 2nd too. Its just so weird how thats normal.
Not really... an easy way to think of it is this: your trans has a primary shaft that engages each gear, this shaft is essentially your crankshaft but on the trans side. Forward gears have a beveled edge, allowing the primary gear (on that primary shaft) to engage 1st, 2nd, etc. seamlessly. The reverse gear, however, cannot have this cut because it spins backwards. This isn't really an engineerig problem, because in theory your primary shaft will be stationary when you engage rev, making a beveled edge a moot point (because you aren't moving). In reality, though, the primary shaft will spin, so going into a beveled gear first will stop it, then allow a seamless rev shift while everything actually is stationary. ;)
Discussion Starter · #13 ·
Thanks for explaining it! That actually does make sense. I can tell you know your jeeps! I'm actually a mechanic but only 18 so I'm still learning. I just figured they would come up with something so it doesnt grind....but first then reverse!
1 - 13 of 13 Posts
