I have seen several Tjs advertised, where someone has removed the carpet, & put Rhino liner into it.
If you wanted to re-install carpet, would you have to remove the Rhino liner first?
Is the Rhino liner sprayed in?
The reason I ask is because I just read a classified ad where the seller says, "... rhino lining on the container tub ...", and I am not sure what the container tub is.
