i have a 95 wrangler with 331 x10.50 A/T and they rub on the leafs in the front when turnin hard wondering if new rims with more back spacing will eliminate the rubbing. and any recomendations on what rims to get.
New rims should help, but there is a solution that will cost you nothing. There is a screw on the steering knuckle that can be adjusted to limit the distance the wheels will turn. Just locate the screw on each side and back them out a couple of turns. Won't cost you a nickel.
