I don't hear super high pitched sounds (birthing issue)
Anyways, my wife pointed out yesterday I high pitched ringing sound she could hear mostly off accelerator. We got home, popped the hood, and discovered it more present on right side of the motor if you looking at the Jeep. Like up front with belts and pulleys.
I immediately thought a belt or bearing pre failure...
Ideas?
Commercial Member
Remove the belt, spin all the pulleys by hand. Replace anything gritty or not spinning smooth.
I did both my idler pulleys (one making noise, other not far behind). Shortly after I noticed water pump had play in it. Finally power steering pump started to chirp.
Kind of waiting for the alternator next....
