1 - 14 of 14 Posts
I'm looking to get a lift for my JKUR and have narrowed down to these 2 kits:
- TeraFlex 3" lift with 8 control arms and TF shocks ~$2200
or
- Rock Krawler 2.5" X Factor lift with 8 control arms and Bilstein 5100 shocks ~2000
The RK kit also comes with the track bars, I would have to pay additional money for the TF track bar (~$250).
Is the TF lift worth the extra cost or is the RK kit just as good?
I'm leaning towards the RK kit and use the difference in savings for other mods. I'm a big believer of doing it right the first time but am curious if I would regret going with RK instead of TF.
I plan to off-road once every 2 months on easy-moderate trails. I also plan to put 35" tires on the JK as well.
I'm not very technical when it comes to suspensions so any feedback from the gurus would be appreciated.
Thanks!
Both are quality and perform well. The edge is in street ride comfort which I would give to TF. I own the RC 2.5 my neighbor owns the TF 2.5 and his JKU rides softer than mine( same tires and air settings ). Although mine corners better:). Off road at slower speeds its to even to really tell.
IMHO go for the kit that has everything included, and use the extra for better shocks.
Thanks Hivedr. Good to know the TF rides softer. What kind of shocks are you running with your kit?
Build Thread Queen
Mike and I both run the TeraFlex 2.5' lift with Rancho 9000XL shocks. We love the ride!
Im running the RK 2.5 and love it! I run it both on and off road, but the reality is that you cant go wrong with either
Did you upgrade the track bar or just did the 2.5 lift and call it a day?
Curious to know if you upgraded the steering stabilizer? I read someone mentioning it was needed.
Build Thread Queen
We just did the lift. Mike's has been lifted for about sixteen months with no issues. Mine has only been four months, but I don't have any issues either.
Good to know..reading your build thread now. Thanks for the feedback.
I upgraded from Bilstein 5100 to Fox shocks. But there are others good ones just my personal preference. The Fox do ride better with the 2.5 RC system than the Bilsteins.
Our 2.5 TF and Rancho 9000s have been in place for about 15 k miles and have performed flawlessly. On and off road. The combination is something that just clicks. Nothing else needed and have close to a three inch lift (no winch) and fairly heavy PS bumpers.
I agree with the above. Both are very solid choices. For best all around ride with good performance I would choose the TF. If you want some extra performance with a slightly firmer ride the the RK. Performance alone it is hard to beat RK.
Good to see you have the budget for all the CAs. It is great to have all them in either case. :thumb:
I did upgrade the SS, but not because it was required. I smashed mine wheeling and it was slightly bent. You can definitely use the stock SS, and if oh feel necessary upgrade from there.
Discussion Starter · #14 ·
Good to know. Thanks!
Looks like there's a rebate on the Rancho's. Timing couldn't any better. Appreciate your feedback.
I'm a little over budget but I guess you only live once. Buy once, cry one...:)
Solid advice, I'll take it! :thumb:
1 - 14 of 14 Posts
