Which has the better base plates? I ordered a Falcon 2 tow bar and a Blue Ox base plate. The company sent the correct tow bar and a Roadmaster base plate. Is one easier to install that the other?
Thanks, Leo
I believe the baseplates are not interchangeable. I believe the Roadmaster Falcon only hooks up to Roadmaster brackets. Blue Ox only hooks up to Blue Ox.
I would call one or the others tech support to ask about compatibility of brackets/adaptors. Or call your local Campingworld install department and they could proabaly help.
As far as which is best, they both have followings, both are very popular.
Roadmaster makes the Falcon 2 tow bar so my guess is they sent you the matching baseplate. Both Roadmaster and Blue Ox are solid companies, many of them are interchangeable. Sounds like you got a good setup!
