Those are the stock kms I believe 255 65 17???khickeyman said:Looks great! What size tires are you running?
And how do you like the shocks ?Six said:I just did this same kit this weekend but with the Rancho 9000xl's. It definitely sits higher and it looks like it'll be an easy upgrade to the max travel.
I did the same lift few months ago but did not replace bump stops as dealer previously replaced my wheels for 35s and mentioned that bump stops were replaced by him then. I am not so sure of that now. Do you know what you had and what you replaced with in regards to bump stops?I think I have 2 inches but would have to double check that.Just installed the rock krawler 2.5 flex with billstein shocks on my rubicon. Also added the exhaust spacer and proper bump stops. I think I gained 3 in the front and 2.5 in the back. Rides well on the highway and a bit stiffer. Pic for anyone interested in this lift.
Awesome. Set them to 3 right off the bat and they were real soft. Bumped them up to 5 and now they ride near to stock.And how do you like the shocks ?
OP might have a different experience but the two hardest things for me were the top bolt on the shock on the front driver's side and torquing the specified bolts to 200 ft/lb without a lift.Very nice. I have the same kit sitting at home waiting to be installed. Did you do it yourself? I've read the instructions several times and feel like I have a handle on it. Were there any unexpected challenges or any pointers that you could share?
The only thing the Procal does is "assist" in centering the steering.Six said:Awesome. Set them to 3 right off the bat and they were real soft. Bumped them up to 5 and now they ride near to stock.
My friend's dad is a welder by trade so he was on hand to do the bracket on the rear.
Edit: And I don't know if it mentioned it in the instructions or not, but you'll have to recenter your steering wheel. I did mine without taking it to the dealer or the AEV procal by having someone sit inside with the wheels straight and adjusting the bracket. It wook two times to get it mostly straight. I'm going to order the procal though and do it that way.
Those are my stock 32" BFG MTLooks great! What size tires are you running?
No spacers, I figure there are so many changes to come that I will evaluate later on when I finish with a few more mods. Also even after a few days I feel it is leveling out a bit on its own.Looks great, did you do wheel spacers?
I know what you mean... I feel the same way and feel this is a good start.I just did this same kit this weekend but with the Rancho 9000xl's. It definitely sits higher and it looks like it'll be an easy upgrade to the max travel.
