Has anyone found an equivalent to Rock Krawler's PITA 3oz Molylube AC1000 grease that comes in a standard 14oz cartridge?
The problem is that NO ONE seems to make a 3oz grease gun that isn't a chinese stamped steel POS that will break and stop pumping before getting half way through the tube of grease. I've gone through three different 3oz guns that have died and wasted the majority of the oh so precious Rock Krawler grease that goes for a whopping $24 per 3oz tube (once you add shipping). :pullinghair:
I gotta think you’re using too much grease or too often. I do it twice a year and it only takes 1 to 2 pumps per fitting. I don’t think you’re going to find any grease gun that is made in the USA these days. The one I have I ordered from Zoro Tools, I believe is made by Westward. I did look for an alternate source a couple years ago and the best I could come up with was a 5 gallon pail.
I'm in the same boat as you. My little cheap 3oz grease gun is a pos. And the grease is $$$
Thanks I'll probably order one tonight.
I have a 14oz Pneumatic Grease gun from harbor freight (the $30 one that is good to run on 1-4cfm) I run off my onboard ARB for greasing my ball joints and tie rod ends up front it rocks. But I need a small one like this!
